A smart tablet manufactured in 2013 by Samsung.
19вопросов Показать все
Window Msg: Unfortunately, Google Play Services has stopped
I've tried restart but no effect
Это хороший вопрос?
Оценка 1
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Try this and let me know..
Settings > Application Manager (or equivalent) > Find google play store/Service > clear cache > clear data > uninstall any updates it may have > disable and enable
Был ли этот ответ полезен?
Оценка 2
3 Комментариев:
Thanks, for the effective and simple solution without the off putting techie talk
из
This worked but you must go through it a few times, and then it clears.Thanks.
из
Nope, doesn't work.
из
i trt but i can not.
Оценка 0
Hi Art, it is a very common problem. I would suggest you to try some of these methods below.
  • Rebooting Android to fix the error
  • Updating the Google Play services app
  • Clear the Google Play services app cache
  • Disable Google Play services
  • Uninstall and reinstall Google Play services updates
  • Wipe device cache
  • Using Play Services Fix Info app"
I am sure these potential solutions will help to resolve this issue of google play services stopped.
Оценка 0
Добавьте свой ответ
Art Weiner будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 8,726
