The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185вопросов Показать все
Is it safe to use adhesive remover on swollen battery?
Hello,
I ordered the iFixit battery fix kit with the adhesive remover. When I opened my macbook, I've noticed two swollen battery cells.
My question is simple : is it dangerous to use the adhesive remover on the swollen cells ?
Thank you !
PS : No, Apple refuses to take care of it for free.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
The adhesive remover its self is not the risk! The poking and physical pulling on the battery is the risk of it rupturing!
So basically take the system outside away from anything flammable. Use care as you remove the battery don't over due the remover and take your time.
I do strongly recommend you wear some gloves with a long sleeved shirt, face mask and eye protection so if you rupture the battery you don't get the material on you. This is more of a worry when the battery is at the point of rupture.
Был ли этот ответ полезен?
Оценка 3
Добавьте свой ответ
Antoine будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 332
