The Toyota Yaris is a subcompact car produced by Toyota since 1999. Between 1999 and 2005, some markets received the same vehicles under the Toyota Echo name. Toyota has used the "Yaris" and "Echo" names on the export version of several different Japanese-market models.
29вопросов Показать все
Air or heat not blowing through vents
When I turn on the knob for air/heat nothing blows through vents. What could be the problem and how much could it cost to repair it? Thanks
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
First off get your car scanned, if you live in the States. Some auto places do it for free.
Check your fuses, and relays. On the fuse box it should tell you what fuse is what. Also the hand book should tell you if you have it.
If fuses and relays are good. It could be a faulty switch.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Kimberley будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 215
