Won’t hold charge
If my iPod doesn’t hold charge is it the battery or the logic board
Это хороший вопрос?
Это хороший вопрос?
Battery. If it boots with a 10W adapter, then the battery needs replacing. Replacing your battery requires a solder and is very hard, similar to an iPhone 2G.
Был ли этот ответ полезен?
Most likely it is the battery that needs to be replaced. If the ipod were damaged in some way then there could be a possibility that the logic board is damaged but the only way to tell would be to replace the battery.
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 108
Are you syncing to a Mac or PC?
из mayer
