LTE-enabled variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
Вопросов 20 Показать все
IPad 5th gen battery issue
Ok so I had a guy bring me an iPad 5th Generation in to my shop with a cracked Digitizer to get repaired. While testing it I noticed the battery shows 1%, so I plug it in to charger and once the charger recognizes it shoots to 100% and will stay on for about 10 seconds then shuts off and turns back on at one percent, within a few seconds shoots back up to 100% and just keeps cycling through.
It was doing this prior to working on it, I went ahead and replaced the Digitizer but cannot figures out what could be causing the issue.
Do you think it’s possibly a bad battery? Software? It has an update available but shuts off before it can update, thought about trying through iTunes but don’t want to do that and then the iPad get stuck in recovery if it shuts down in the middle of an update
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
Выбранное решение
UPDATE: upon further inspection I can confirm it’s most likely a bad battery. I spoke with the customer and they said it stays plugged into a Square register dock 24/7 which leads me to believe the battery is shot
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
chad будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 993
