Дата выхода 25 сентября 2015 г. Модель A1687 / A1634. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 64 или 128 ГБ памяти; в цветах: Серебристый, Золотой, «Серый космос» и «Розовое золото».
1041вопросов Показать все
Is there a way to fix the tip of an Apple charger that had broken off
My iPhone fell of the floor with it being charged in that it hit the wrong way and the tip broke off of the cable and I was wondering if there is a way to fix it.
Это хороший вопрос?
Оценка 6
Добавить комментарий
3 Ответов
Выбранное решение
I guess that depends on where the break occurred. If the metallic part broke off, there's not much you can do. If it broke where the wire is coming out and you have some wire to work with, then you could splice the conductors back together. However, it's hard to say just based on your description.
Please post a picture (add it to your question) so that we can see where the damage is.
Keep in mind that there is a lot of electronics in the hub of the connector so it's not a simple pass through connector.
Был ли этот ответ полезен?
Оценка 5
5 Комментариев:
&&^& &&^& &&^& the tip of my charger broke I’m going to cry my mom is going to be so mad....
из
Nonononono I need my iPad
из
I went to put my charger in but it didn’t charge so I took it out and the tip was left in my phone. I screamed and I did cry a little because it was a really nice charger and I got it for my birthday. My mum was very angry and this happened yesterday so I googled how to fix the end of a charger and found this so fingers crossed it works ??
из
The top of my phone where you put I in the phone? Yea it fell of.
из
I was getting my phones and I accidentally kneeled down on my charger and the tip of the charger that was put on the charging station came off and there are 3 wires poking out and I’m scared if I try to put it back it might spark and electric me.. it was from my birthday and I’m about to cry..
из
What BS responses, But yes, it’s an easy fix, just buy the tip. They actually make aftermarket repair parts for the charger. You can buy it on alibaba! Costs about $5 shipped.
Оценка 1
4 Комментариев:
Use some petroleum jelly of Vaseline
из
Really, if it’s the tip, I would recommend going to a professional, and they would take care of it.
That’s all I can really say.
из
thx but my thing came off that the reason and it was coming apart
из
Why bother fixing a cable? You can get an MFI certified cable for as little as $4. And a genuine apple cable from an authorized apple retailer for $17.
из
my favorite 12 foot long charger just broke because my brother sat on it and im so devastated :( can i like… glue it back it there ?
Оценка 0
Добавьте свой ответ
John proctor будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 26
За последние 30 дней: 135
За всё время: 23,726
