What is error E:62:10 mean and how to repair
what is error E:62:10 mean and how to repair
Это хороший вопрос?
Это хороший вопрос?
Dan JN that is a lens error. Could be generated by a stuck lens. Try to extend the zoom immediately after you turn the camera on. Then remove battery while still in zoom tap around battery case a few times.Then replace the battery and see if that will help. If not you will need to either repair the lens or replace it.
Был ли этот ответ полезен?
Sony RX100 III - I extended to telephoto and removed battery then jiggled the lens a little. When turned on again the problem was not there. (Don't know for how long.)
Bro, I created an account on this site just to thank you because it worked!... Greetings from Venezuela
this really works. Many thanks.
That did it! I wonder how many mysteriously blurry shots were caused by this! You'd think with all the smarts and memory in the camera, they could have at least spelled out LENS ERROR instead of E:62:10. But anyway, maybe now it will actually focus! :-) Thanks a lot!
This was helpful. I too tried this , now it doesn't show that error.
Hello,
Sorry to hear you have the same problem too, but again this is a very well known problem that a lot of users have. Read the full story at http://sony-e-62-10.atspace.cc/. If the device is still under warranty, bring it as soon as possible to an after-sales service center and let it fix. If it is not under warranty any more, the workaround procedure described in https://www.youtube.com/watch?v=S53D3EfD... may help, but it needs to be executed each time the device is powered on. You may also contact the support services of SONY to make them aware and/or try to invoke a hidden defect.
Regards,
Glad to see additional info because despite being glad to see a fix in the post before this one, the problem does keep returning. Not surprised its a "lens error", as the camera took blurry photos way too often, even before this error code started. Think its probably best to replace it at this point. :-( Oh that link to sony-e-62-10.tk doesn't seem to work (just times out)
Hi, Thank you for your comment. Indeed the workaround has to be repeated on each power-on cycle, but as far as I am concerned the stabilizer then works again. Of course this is not a final fix to this (recurring) problem but I read that most service centers simply replace the complete lens block which makes it cost above 300€ - more or less the cost of a new device. As seen the number (and the proportion) of people having exactly the same problem this is not a normal situation. PS the link to http://sony-e-62-10.tk should work, I test it regularly, maybe it was a temporary issue of the server
Due to Dot tk scam the website has now been moved to http://sony-e-62-10.atspace.cc/
Hi
After having to remove the battery very often to clear the same error for my 4K camera (FDR-AX53),
I noticed that if I hold the camera vertically, with the lens pointing up (seems to also working pointing down), instead of horizontally, I never get the error as the lens assembly is easier to move / not fighting gravity as much.
Whereas I get the error at most horizontal startup. Whatever the previous zoom position.
I hope that info may help other persons!
B.
Added : Or from the .cc website, maybe the flex ribbon is less broken in that direction in my case… But for me the stab starts “too strongly” and hits the ceiling when the camera is horizontal, then goes in error. So it may just be the control system which is badly configured, and should move slower / not as far and or be allowed to use more current.
Hello,
I have the same problem too. This is actually a problem that happens very frequently with Sony devices.
I found over a hundred forums where users have had the same problem : take a look here.
I documented the same workaround as above, but as far as I am concerned there is no need to tap the device.
Hope it can help.
It started yesterday on my DSC-HX50V. My photos were getting dark on the edge, like when someone put the finger on the lens while shooting photos. The turn-on/zoom/reset procedure didn’t work, but i managed to fix it using a lantern. With the lens fully extended and the battery off, I illuminated the lens internals, trying to not put the light directly over the image sensor. On the very bottom one ring was a little off-center. With a little tap on the side of the camera body I managed to slide it back to the correct position. After that, no more black edge an the error code is gone. I think maybe the camera was hit during transport.
OMG! I got this problem today, and you know, after try all guides above but still not work.
I just turn off camera, shake and tap lightly on the area nears lens, and it works. The error E:62:10 OFF.
Hura!
Same problem for me. I had 2 Sony camera’s. The previous one had the same error after 2 years. The new one has this problem already within 2 years. I have to return the camera to the supplier who takes care of the reparation.
Rx100 iii :) I have the error from a drop onto a hard surface - cannot see any effect on the resulting pictures at all, all very clear and sharp. There is some denting above the multi plug hole but everything works just fine.
I had this problem, l did what you said it worked great thanks
Hi, I have the problem E62:10. Tried all the remedies, still keeps coming back. However my photos are still ok!!!. even on full zoom. Strange!! Wayne W
Hi Wayne, it depends on which model you have. If you have a DSC-HX model than the procedure documented on https://www.youtube.com/watch?v=S53D3EfD... is the best one and does not involve hitting the device, which can always cause collateral damage. However upon each start-up the camera will repeat the internal check-up routine and will display the error again, which means that the procedure indeed needs to be repeated.
To see the effect you need to take a picture in the same conditions, before and after executing the workaround procedure. Compare for instance the videos at https://www.youtube.com/watch?v=kY4de-OJ... (before) and https://www.youtube.com/watch?v=XDjE_yeZ... (after). As it involves the stabilizer, differences will indeed appear in conditions of high zoom and low light, where the resulting pictures will definitely look more fuzzy when the stabilizer does not work any more. More details at http://sony-e-62-10.atspace.cc.
Če ti kamera pade na tla. Kaže napako E62.20. Pomeni da ne more izvleči objktiva. Verjetno. To se mi je ravnokar zgodilo. L.p.
In English yet!
If your camera falls to the ground. Shows error E62.20. It means he can't pull out the lens. Probably. That just happened to me. L.p.
Thank you for sharing your experience. Indeed, if you let the camera fall to the ground, you may damage the lens mechanics. However, E:62:20 is a different code than E:62:10. All E:62 errors have to make with the stabilization mechanism, see https://www.sony.com.au/electronics/supp.... The structured default cause by the flex ribbon displays E:62:10, see details at http://sony-e-62-10.atspace.cc.
За последние 24часов: 42
За последние 7 дней: 237
За последние 30 дней: 1,080
За всё время: 50,871
Tried many times all recommendations and the error still appearing
из Amy Houtz
