Can´t click with my Roccat Kone XTD
If I turn on my Roccat Kone XTD and I want to use it, my mouse doesn´t left- and rightclick. I don´t know what to do please help.
Это хороший вопрос?
Это хороший вопрос?
When the mouse is older than 5 Years the buttons might be broken, but you wrote that with a hotkey they work ?
So you should remove the driver and also delete the profiles etc. by deleting all folders and files from roccat on your pc. AppData, Documents, Common Files etc. …
Than restart your pc and install latest driver from the official roccat website.
Or you try to use the “Reset” Options inside Roccat Software (Driver Reset)
Был ли этот ответ полезен?
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 16
За всё время: 1,951
@blsquad can the mouse cursor move ???
из Augustine
Yes with the curser is everything ok. And if I use a hotkey on my mouse I can right click, but not left click.
из BlSquad
@augustine Yes with the curser is everything ok. And if I use a hotkey on my mouse I can right click, but not left click.
из BlSquad
Hi @blsquad , If you use your mouse at another PC, does left the left click issues still persists?
из Augustine
Have you installed the according drivers for the mouse?
из Niels
