wheres the horn fuse
where can i find where to put the fuse for the horn to work?
Это хороший вопрос?
Это хороший вопрос?
Open the driver's side door, you will see a small cover on the side of the dash that needs to be pulled off. The fuse for the horn that is inside also feeds the lighter. There should also be a horn relay somewhere on the firewall that will click when you push the horn button on your steering wheel. It can be very quiet though, so make sure you have everything off when checking - & maybe even have a friend help listen. the relay is the most common failure part, so that'd be where you should go first. It is often on the firewall near the steering column, but can also be in a fuse panel under the hood
Был ли этот ответ полезен?
When i lift or even tap the steering wheel the horn honks.its a 1999 chevy cavilier
I just want to shut it off for now how do i do that easiest way.?
Pull the fuse
За последние 24часов: 0
За последние 7 дней: 10
За последние 30 дней: 32
За всё время: 8,896
