My monitor keep losing signal
Hello to everyone reading this,
i just did buy a new computer :
amd 3 ryzen 2200g vega graphics
hyperx (4gbx2) 3200mhz
Gigabyte psu 650
gigabyte ab-350 gaming 3
toshiba 1tb
i did have some problem installing the graphics drivers when windows crashs
i did find the problem is lowering the memor clock rate. But this is not my problem now.
well my monitor did have this problem once i did just turn it on with the pc,
from once in a while sometimes every 3 min for like half an hours its turn into white noise with no sound and it does not show me display until i turn off the monitor ans switch it back on. I did try to set the monitor manually, also i did try to change my dvi cable
i dont know the problem, could someone please help me.
Это хороший вопрос?
Hi @josephtoufik ,
What is the model number of the monitor?
Does it show the display OK, with no problems after you turn it off and then on again or does it continue to have the same problem?
Have you checked that the monitor can handle the resolution that you've set in the graphics adapter display properties?
Can you try the monitor with another computer to check if the problem is with the monitor or the PC?
из jayeff
