Electromechanical calculator which graced many an accountant's desk between the 1920s and 1960s. The underside of the machine has a slot which, if you peer into it with a flashlight, will reveal the stamped designation LA-160-(serial number).
2вопросов Показать все
Reccomendations for restoring and cleaning?
I've recently acquired an LA-160 and I will be using your guide to dissassemble it and make sure the innards work correctly. I was wondering, however, if you have any advice on cleaning the insides or anything?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Dug around to double check my work and found this. http://www.vintagecalculators.com/html/m...
Contained within are a operating manual and a more detailed service manual that contain adjustment and lube
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Brandon Mather будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 117
