Ремонт и общая информация об устройстве Plantronics Backbeat Fit 2100 — беспроводных спортивных наушниках, выпущенных в августе 2016 года.
Can I disassemble my Plantronics Voyager 5200 charger case
Hi. I have problem with the top connector in my Plantronics Voyager 5200 charger case.
I need to open the unit but I can´t
Can yo give me a video explain it?
This is the charger case: https://www.amazon.com/Plantronics-Voyag...
Thanks !!
Это хороший вопрос?
Счет 3
3 Комментариев
do you any ides of what you're going to do if you get it open?
из
Maybe. But i know how unblock and open it
из
Do you have any pictures? is there enough space to add a wireless changing inductor? My handy supports wireless charging of equipment - it would be great to upgrade it ;-)
из
Добавить комментарий
5 Ответов
Выбранное решение
Yes, you can open this case. There are two small hidden screws. They are near the hinge, and under the rubber liner on the inside of the case. You call peel it back with a small, flat tool and maybe some gentle heat to soften the adhesive. Start in the corner near the hinge, where the ear piece sits when the headset is stored in the case.
After removing those two screws, you can pry around the top edge of the case to release the snaps and it should come out. There are some small magnets to retain the headset, so don’t lose them when opening.
Был ли этот ответ полезен?
Счет 8
1 Комментарий:
i had a usb dongle stuck inside the case that i needed to get out. disassembling helped.
see post below from another user with pictures.. that further helped locate those two screws "inside" the case :)
из
Thank you gee-one for explaining this, I've been struggling to open this thing without ever realizing that there even was a liner!
As noted in the accepted answer, the two screws are in front of the hing beneath a rubber liner inside of the case that the earpiece rests on. I was able to slip a thin metal jimmy under one edge of the liner and lift it up pretty easily.
Счет 4
1 Комментарий:
I do not see a way to peel off the lining as indicated in your picture. Where did you recommend to start, peeling off the layer, The usb from my mouse is stuck inside, I get annoyed when I have to spend money for another receiver, your help appreciated in advance.
из
Before you tear it up, I'd check to see if it is still under warranty.
https://www.plantronics.com/us/en/suppor...
DATE CODE EXPLANATIONS
Each Plantronics unit is imprinted with a date code to assist in tracking warranty information. The date code can be found on the plastic housing on the top half of your headset or, if your unit is an over-the-head style, the date code is located under the foam ear cushion. For more information you can contact technical support.
WARRANTY TERMS
Warranties for products last one, two, or three years (depending on the product and country you are in) starting from your original date of purchase or according to your products’ Date Code. For more information you can read the worldwide limited warranty terms and conditions.
Счет 2
I got mine opened and found the battery is soldered in.
Li-Ion Polymer Rechargeable Battery
DIJ652037SA 1ICP7/20/37 (RED+)
3.7Vdc 440mAh 1.628Wh
207650-02
Счет 2
1 Комментарий:
I got mine open and found battery
AHB651935PST-01
420mAh 3.7v Li-Ion
After some digging, I couldn't find a replacement for either battery model. Your model seems to be made by Tianjin Lishen Battery Joint-Stock which was auctioned off sometime in 2021, and mine seems to be compatible with charging case for Sennheiser CX Plus released in late 2021, but again, without a replacement.
из
Hey. did you manage to replace the battery? Any parts, recommendations?
Счет 1
Добавьте свой ответ
Esteban Yanson буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 21
За последние 30 дней: 94
За всё время: 6,427
