Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
154вопросов Показать все
Slow Charging, 15% on 2 hours
Hi,
Im having an issue with an iPad 3.
- Already replace the dock connector, but the battery charges real slow, about 15% in 2 hours. Rested multiple flex connectors, issue persist.
Any one had encountered this issue?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
It's probably battery related. However, before replacing the battery, try a known-good original iPad charger and Lightning cable to eliminate that as a potential source of problems.
If you have confirmed that the charger and cable are good, the try to replace the battery, following this guide, to see if that solves the problem. Otherwise, it could be a logic board/charge circuit issue.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Robert G будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 136
