If battery is dead or removed how long will the memory last/
How long will the flash memory last without power?
Это хороший вопрос?
Это хороший вопрос?
Your phone has two types of memory: RAM & Flash, just like a desktop or laptop computer.
If you properly shutdown your phone anything that is open in RAM will be saved to flash at which point the lifespan of the flash would to the limitation (20 or so years).
If you fail to shutdown your phone then you risk corruption of anything that is open and not saved. Your phone can hold the data in RAM a few weeks with whats left in your battery if its still present. This is called deep sleep mode.
Был ли этот ответ полезен?
За последние 24 час(ов): 0
За последние 7 дней: 3
За последние 30 дней: 5
За всё время: 884
I found first generation with out baturday how long does the flush memory will last
из Farouk Guessford
@Farouk Guessford - A good 10 years more ;-}
из Dan
