An E-Cigarette vaporizer is a device used to heat a substance, such as cannabis or tobacco, to a temperature at which it releases a vapor that can be inhaled. It is a reusable alternative to traditional smoking.
121вопросов Показать все
How to tell what lcd connector will fit?
Hi I have a touch screen mod, it's a laisimo. It arrived to me with a broken lcd connector on the board. Obviously you can't just go to the shop and buy a new connector, Any idea how I would be able to know what connector it is? For example would a iPhone / Samsung lcd connector fit?
Thanks
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
I would just return it and get a replacement unit.
Connectors vary from device to device so without seeing the connector it would be a guess. Often these are custom parts given the size limits.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Well if if was under warranty I would return it but considering I purchased it used and its several years old I doubt if they would replace it.
из
Then they scammed you into buying their broken device. I would still try to get my money back in that case.
Did it arrived in a crushed box or improperly packed? You might get some relief from the carrier if you still have the packing.
из
Добавьте свой ответ
John будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 6
За всё время: 46
