Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
My earpiece speaker is not working.
Hi, I have two iPhone 6's where the earpiece speaker does not work. I have changed iPhone screens multiple times on various iPhones so I have knowledge of the procedure. However, after trying to replace the earpiece speakers on these two iPhones with multiples replacements including purchasing replacement screens where they are already pre-packaged/built so all I have to do is connect the cables to the screen, home button ports etc, it's still not working. Everything else for the connection works like the proximity sensor. It's just the earpiece speaker that does not work. Any help? Thanks.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (2)
When replacing a iPhone 6 screen it is super common for the proximity flex cable to have a small tear. I would recommend looking over the cable to see if there are any tears. 99% of the time it is a small tear in the corner closest to the connector. However, it could also be a bad speaker, but i have only seen that with water damaged phones.
Был ли этот ответ полезен?
Оценка 0
I bought a brand new screen which is already assembled, so all you do is clip in the cables and tried that and it still didn’t work, but I’ll check later today.
Оценка 0
Добавьте свой ответ
Kymani Steer будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 43
