2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580вопросов Показать все
Logic Board Replacement: from Late 2013 IG [2.0GHz] to any compatible.
Hi, so I got this MacBookPro11,2 [i7-4850HQ 2.0GHz, 8GB Ram, Iris Pro 5200] but it's water damaged causing the CPU to be capped and the fan running 100% all the time, and having stability issues in general. Although the condition outside is "mint."
My question is, how many boards are out there that is compatible with this exact model? [As far as I've seen would be the late 2013 itself and 2014, while 2015 had a different trackpad connector because of force touch.]
Current board layout: 820-3662-A [820-3662-03] [Same exact one as the teardown guide used.]
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Only the late 2013 and mid 2014 models are compatible. the rest is different.
If you are going to replace the logic board, make sure there isn’t any fluid damage on any other parts (display connector, battery and keyboard/trackpad, because they might damage the new logic board, especially a bad battery.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Neon будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 94
