What is this, a backlight or diffuser issue?
I wonder if this is worth fixing, or if I should just live with it ?
Update (05/23/2018)
The model number is UN55JS8500. It's been a great set for the two years I've had it, and then one day these lines show up.
Это хороший вопрос?
4 Комментариев
Those look like reflections from ceiling lights or a bit of backlight bleed. Anyway you can circle which part you are referring to?
из Anthony Kouttron
It's the horizontal lines starting on the right edge of the screen. There is a window reflection closer to the center. I've seen backlight bleed before, but never in the shape of lines.
из radiasean
There is a video on youtube by a repair technician on a 65" like mine but same model as yours. On opening the set he found the diffuser screens were melted by the lights allowing the lights to show on the edges. He states the problem is setting the backlight on the picture menu to highest setting. He recommended setting on 16 or at least less than then highest setting of 20. According to postings though, this seems a problem with Samsungs and the complaints are that Samsung is doing nothing about a possible problem.
из youngjl50
I have a Samsung UE40H5500AK in the process of finding the fault, I forgot which order the diffusion panels go? one has locating tabs on the edge for the frame, and the other has just flat edges. which one goes directly in front of the led strips?
из Jean-Luc Picard
