S8 новейший флагманский смартфон компании Samsung, представленный на Unpacked 2017 в апреле.
304вопросов Показать все
Phone is echoing not software issue
Hello,
My galaxy s8 is echoing for people who are talking to me on it. They can hear themselves on their phone. I have tried all the software fixes I have found available, and I am pretty sure it is a hardware issue. I was just curious if I should replace the earpiece speaker or the i/o daughter board.
Это хороший вопрос?
Оценка 2
2 Комментариев:
Hi Stephen, just wondering whether you’ve had this issue resolved? Am facing the same problem myself, but it only started happening after a daughter board charging port replacement, so I’m not sure whether replacing it again will resolve it.
из
Hi guys, I have the same problem after charging port replacement.. Did anybody resolve this issue?
из
Добавить комментарий
2 Ответов
Try Reset network settings or turn off noise reduction in call settings
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Hi Steve, thanks a lot for your fast reply.
Unfortunately, in Android Pie is no option like “noise reduction" in call setting and what do you mean about a “network reset”? There is also no option like this..
из
Via settings -reset -reset network settings
из
The answer was replacing the i/o daughter board
Оценка 0
Добавьте свой ответ
Stephen Arends будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 6
За последние 30 дней: 7
За всё время: 287
