Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
299вопросов Показать все
issues with car electrical system
Help..I'm not sure what's going on..first off I have a 95 chevy 2500..both the brake light n abs light was on when got it..I plugged in wire for trailor hitch n pressed brakes to check lights n popped fuse replaced #1 brake fuse but it kept popping..so I unplugged the trailer hitch wire for lights..replaced fuse again..it worked this time so I decide to take truck up the road I got about 2 blocks from my house n smoke started coming up around the steering wheel..smelled like wires melting..I haven't a clue..I just changed the fuse that's it..any ideas..
Это хороший вопрос?
Оценка 1
2 Комментариев
It melted the wiring harness to the brake light switch..
из
Headlights went out.
из
Добавить комментарий
1 ответ
Выбранное решение
Definitely a short circuit. Now where it is I'm not sure.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
short in the switch itself try replacing it
из
Добавьте свой ответ
John Faust будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 7
За всё время: 334
