Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
Screen Replacement Problem wigh frame and LCD
I have replaced many screens before and they have worked great but i have had a couple what fit but the bottom right doesnt really clip into place an the is light at the right side of screen, also the is like a white dot at the top of screen on LCD, The screen is not damaged in anyway but why do these problems occur? I have sent the screen back anyways.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Assuming the housings weren’t bent or warped, then you may just be getting low(lower) quality screens. Cheap screens are notorious for poor fit, cheap materials and poor assembly (dust between the LCD and Backlight). If you are buying from a reputable or quality supplier, them talk to them about the issue and they should make things good.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Adam Powell будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 69
