The Sega Game Gear portable gaming device was released in 1991 in competition with the Nintendo Game Boy.
41вопросов Показать все
Vertical coloured lines no sound
Hi
I'm having trouble with my Sega Game Gear. When the unit is powered up the red power light illuminates however the screen only displays verticle coloured lines across two thirds of the screen from the left. The remaining third is black. There is also no sound.
Any idea what the problem might be ? Is it repairable?
Thank you
Regards
Mustafa
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
I would guess this is also a capacitor issue, or possibly a bad LCD screen.
You should try it out with other games as well of course.
Capacitors go bad over time and they affect screen and sound and needs to be replaced.
You can find good guides now if you google it, does require solvering thought.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Thank you Erik, I'll try changing the capacitors.
PS I have tried other games it's exactly the same...
Thank you once again
Regards
Mustafa
из
Your welcome, Good luck with the cap change!
из
Добавьте свой ответ
Mustafa Desai будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 9
За последние 30 дней: 25
За всё время: 1,818
