A1708 / EMC 2978 — Released October 2016, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). The function key version packs an Intel Core i5 and two Thunderbolt 3 ports.
216вопросов Показать все
Adaptor for MacBook Pro A1708 SSD
Hi.
Anyone know where to find correct adaptor for internal SSD for a MBP A1708.
Mainboard had water damage, and need to save some files from harddrive.
Best Anders
Это хороший вопрос?
Оценка 3
8 Комментариев
Anders Laursen
Hi. Have you solved the problem? I also need to copy the data from the SSD.
из
Hi, I too am on the hunt for such an adapter. Let me know if you have any leads.
из
I have not yet seen any adaptors for these type of SSD in macbooks. Still looking!
из
Ive found them eBay
из
Sash, why say that and not leave a link?
из
Показать 3 больше комментариев
Добавить комментарий
6 Ответов
Выбранное решение
To date, no one that I have been able to locate has an external enclosure for this model.
Here’s the only thing I have found for data recovery
Apple Customer Data Migration Tool Kit 076-00236 for MacBook Pro 2016-2017
Here’s the skinny on it:
https://9to5mac.com/2016/11/24/apple-spe...
Here’s where to buy one:
https://www.ebay.com/itm/New-Apple-Custo...
If you can’t find a shop with one, you can always buy it, use it, then try to resell it
Был ли этот ответ полезен?
Оценка 3
1 Комментарий:
This is not the solution for these models. What you link to here is for the models with onboard SSD which can be accessed via lifeboat connector that you link to.
из
Sorry to say there is none by any 3rd party presently ;-{
The best you can do is to find a friend with a Fn model to swap out the drives so you can then copy off the data to an external drive.
The other path is to go to an Apple Store see if the can help you. They may try to convince you into buying a new system and having them swap over the drives (if its not damaged).
Оценка 1
4 Комментариев:
Hi Dan,
Thanks for answer.
Any idea as to how long it usually takes before 3rd party adaptors are available for MBP models?
Best
из
Between now and then ;-}
I have no clue, sorry
из
Found this MacBook Pro A1708 PCIe SSD Recovery Adapter Smart $399.00
https://www.recoveryrus.com/product/macb...
из
@Robert Lee - Wow! Way to expensive! But if you cant borrow a friends system to salvage your data I guess you have no choice. Best to setup a backup system and use it as it will be best solution over time and be cheaper! It also is only offering the slower USB3 connection Vs the better being USB-C.
из
Оценка 1
1 Комментарий:
HowieB have you tried the (A1708 PCIe SSD Recovery Adapter Smart)?
из
Bummer, I’m in the same boat you are Anders. I don’t think Myers’ solution applies to the A1708 because it has the PCIe NVMe SSD card in it. But I did learn something very useful I know I’ll need the migration tool for the A1707 in the future and already came up as needing data but then customer found some on the cloud and was good. Nevertheless, all my searches came up empty for an adapter for the PCIe NVMe SSD.
Оценка 0
I’m surprised OWC hasn’t made one yet.
But then again, they’ve kinda fallen off the ball in the last few years. Took them forever to make a Thunderbolt SSD enclosure.
Оценка 0
only option found
MacBook Pro A1708 PCIe SSD Recovery Adapter Smar $399.00
Оценка 0
Добавьте свой ответ
Anders Laursen будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 32
За последние 30 дней: 109
За всё время: 11,205
