Where is the intake air temperature sensor located?
My check engine light is on so I did a code check at my local parts store, the scanner said my problem is an intake air temp. sensor. My problem is I can,t find it. Please help. The reason I had it checked is because it takes me 30 min. sometimes to get it started. I've replaced fuel pump, air charged sensor, head work done, stopped the heating problem now I would like for it to start when I turn the key.
Это хороший вопрос?
Счет 2
1 Комментарий
trying to find IAT sensor on my BA 6cyl falcon auto
из
Добавить комментарий
2 Ответов
Выбранное решение
chadell if you are looking for the physical location of the sensor, it is on the left hand side of your engine and all 4 cyl and 1998 models have the intake air temperature sensor installed in the air cleaner housing and it is only 2 wires. Check the attached image ;-) it also helps if you give the error code that you originally got.. anyhow here you go.
Был ли этот ответ полезен?
Счет 3
2 Комментариев:
Turkey - I realized after reading your answer that chadell may have been stating that he couldn't find it on the vehicle not that he couldn't find the part ;-)
из
mayer, happens to me all the time it just shows we are all humans ;-)
из
Here you go: http://www.google.com/search?client=safa...
Счет 2
Добавьте свой ответ
chadell буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 11
За последние 30 дней: 24
За всё время: 9,945
