Why is my trigger stuck in forward or reverse
Trigger is stuck on unless the battery is removed or the directional selector is between gears. How do i fix it or where can i buy the parts.
Это хороший вопрос?
Это хороший вопрос?
Planemech -
I occasionally have that issue with one of my drills. I spray WD40 into and around the trigger and work it back and forth vigorously. Let the excess drain out. Usually that works. Electrical contacts are well above trigger housing area, so no problem there.
Good luck,
Russ
Был ли этот ответ полезен?
За последние 24 часов: 2
За последние 7 дней: 4
За последние 30 дней: 26
За всё время: 4,066
1 Комментарий
It is a dewalt dw929
из planemech_2
