1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
192вопросов Показать все
MBA 2011 11" mainboard swap
I have a MacBook Air 11" from 2011 with 64 GB SSD and 2 GB RAM. Nice machine, I look for an 4 GB logic board swap for it.
What models are usable for that, all 11" from 2011 up to 2014 models?
Это хороший вопрос?
Оценка 0
2 Комментариев
The SSD drive's interface in this model limits your choices. The newest models use a different drive and the iSight camera connection to the logic board is different as well. Basically you are locked in with the Mid 2011.
из
oh, I didnt know that, thanks, Dan..
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
This is the only logic board IFIXIT has right now: MacBook Air 11" (Mid 2011) 1.6 GHz Logic Board There is also a 1.8 GHz board but you’ll need to look online as they are very fleeting as many people want them. Here’s the IFIXIT guide to put it in: MacBook Air 11" Mid 2011 Logic Board Replacement
I wouldn’t spend to much on this system as before you know it it will cost more than a new system. As far as a new system… Rumor has it Apple will be introducing a newer Air system either at WWDC next week or later in the fall. If your system is working right now I would hold off to see what they do.
MacBook Air 11" (Mid 2011) 1.6 GHz Logic Board Изображение
Продукт
$79.99
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Jamba будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 67
