The Nikon Coolpix L32 is a digital camera that was released in 2015 by the Nikon Corporation.
12вопросов Показать все
Why is it turning off to prevent overheating?
My nikon Coolpix l31 is turning off to prevent overheating in under 30 seconds of having turned it on. This started about a week after I got it. Haven't used it much since, got it about 2 years ago.
Это хороший вопрос?
Оценка 2
Добавить комментарий
2 Ответов
the likely answer is one of two things. A short on the board, or a bad internal resistance of the battery. If you replace the battery, and it doesnt fix the issue, the most likely scenario is that a board level short is drawing too much current. replacing a logic board is usually not worth the cost of the repair, and i would suggest replacing the device at that point.
Был ли этот ответ полезен?
Оценка 0
Nikon l31 modal overhiting problem
Оценка 0
Добавьте свой ответ
Kole White будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 9
За последние 30 дней: 20
За всё время: 763
