no power on to my nokia 5130
my nokia 5130 express music has been damaged due to interuption while updating. As a result my phone is no longer turned on. Please i highly needed your help..thanks more power.
Это хороший вопрос?
Это хороший вопрос?
richmund, try to reset your phone. These was posted on the other threads
1. *#7780# - Restore factory settings - resets all the settings to the default ( you will not lose any data)
Make sure you back up your data as you will lose all of it when you perform option 2 or 3 on this list. The default code for ALL operations listed here is 12345
2. *#7370# - Reformat your phone (out of the box, tho keep in mind that most newer nokia phones at least n series, e series and s60 based phones have udp - user data preservation so not ALL data may be lost. still it is a good idea to always do a back up of your stuff.)
3. This you perform as a last resort. Nothing else is working.If the phone is not showing any activity, proceed with hard formatting , turn off your phone, hold the following buttons while pressing the power button. (the default code is 12345)
hard reset - hold the following buttons *, 3 (number button) and talk/green key. turn on the phone and do not release those buttons until you see the Nokia boot up screen. once you feel the phone power up you can let go off the power button while still holding all three buttons ( for Nokia 5800XM - use the following buttons to do a hard reset, GREEN/RED/CAMERA keys pressed all at once on power up. this will only work on 5800's that have firmware version 20... and up. )
Here is a forum that deals with it. Start there and see what you get. All is not lost ....
Был ли этот ответ полезен?
gud day..
is it okay even though my phone is not functioning, i mean(not turning ON), still can i perform resetting?
Please help me..thanks.
This comes from various Nokia sources since you are not the only one where this happened. I think point #3 is most interesting to you. O f course do check on all of those. At this time you do not have much to loose. If it works, great. If not we keep looking for solutions...:-)
Good day, my phone doesnt want to work when i turn it on its just showing he nokia logo but not going forward even though if i try switching it off it doesnt want to go off nether
plz i need your help, what can i do about that...?
За последние 24 час(ов): 1
За последние 7 дней: 4
За последние 30 дней: 15
За всё время: 24,078
2 Комментариев
Do you know of any sort of procedures for resetting the device?
из Adam Hintz
richmund:
no. i dont know any sort of procedures for resetting the device. Please help me
из richmund
