Samsung Galaxy S7 (SM-G930, SM-G935) — смартфон седьмого поколения линейки Galaxy S, анонсированный компанией Samsung Electronics 21 февраля 2016 года на MWC в Барселоне[
369вопросов Показать все
Why is my galaxy s7 edge making a weird sound?
I haven't had anything happen to my phone but here lately the volume cuts in and out while watching YouTube or Netflix and it will make a random popping sound when I'm not using it. It's also overheating often.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Some possible issues and fixes for you.
1. Do a software update, this is found under General settings normally.
2. Update YouTube app and Netflix. Try a different app that would normally always have perfect sound.,Example: Pandora
3. The speakers may be going out on your phone. This would require the back glass to be removed and the speakers replaced. If I am right this will either be next to your Charge port on a flex.
Был ли этот ответ полезен?
Оценка 0
Hello,
If this happens on different apps like Netflix and YouTube as you said, it must come either from the software, in this case veryfying if there is a new update and if not resetting the phone completely could solve the problem, or it comes from the speaker, then you will have to change it.
Оценка 0
Добавьте свой ответ
ajnunn98 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 1,552
