The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185вопросов Показать все
What could cause the display to stop working?
Hi
I was watching a movie when display turned off and on couple of times before it died completely. I connected external display to make a timemachine backup. That said macbook itself worked well, its just the display that died. It's 3.1GHz, 16GB of RAM, and 512GB SSD so still keeps high price on second hand market so despite being out of warranty I took it to the genius bar to check it out. After short inspection Apple Specialist said it is water damage, pointed upper right corner, requiring minimum of new logic board, but might be not limited to. So I left it for full inspection and quote. Now, I don't recall any water spill or anything bad happening to my macbook hence my question - what could cause this issue and could something else make a damage that looks like a water ingress?
Thanks,
Pawel
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
I don't know about the water part, but I know that some older Macbook (pro)'s had problems with wire wear due to bad mounting mechanics for the hinge.
Laptop screens are constantly closed and opened, so the cables inside the hinge are continously moving, pulled on etc... This could cause a display to randomly stop working.
It's also possible your backlight stopped working, you can try to shine a torch through the Apple logo and see if you get an image on-screen.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Pawel будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 39
