An easy to use 1-drive USB 3.0 storage and backup solution for PC and Mac computers
1вопросов Показать все
Can a Buffalo DriveStation HD be optimized?
Is there a way a Buffalo DriveStation (2TB), which I use for recording TV programs, can be optimized or defragged? I'm having the same problem as the last DriveStation (1TB) I replaced with this one and I was wondering if there was a way to fix it. The problem is that it doesn't always record programs to their completion and/or there is bad pixilation interspersed on some shows I record,(but not all).
Any clues?
Thanks in advance..,
T.A.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
You can defragment through a pc, not sure if that would fix it or not. Just right click go to tools and defrag.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Hi Derek,
Thanks for the suggestion. I just tried to mount the Buffalo drive to my old Windows laptop,
but it's not showing up. I tested the USB port with a flash drive, so that's not a problem...
For some reason it also shows up on my Mac Pro desktop and I ran Disk Utility on it, but no change. And I'm pretty sure the drive is probably formatted for Windows...
I wonder if Buffalo makes their drives specifically so they can't be fixed, but rather replaced?
Or maybe there's some kind of format problem? I wonder if there's another way to do it?
Thanks for any other suggestions...
TC
из
Добавьте свой ответ
tokyocroc будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 5
За всё время: 115
