Repair guides and support information for televisions manufactured by RCA.
181вопросов Показать все
TV defaults to Analog
I have an RCA TV, model number 27V414T. It is an analog and digital TV - it came out right before everything switched to digital.
The problem is, it defaults to analog; and the only way to switch between analog and digital is with the remote. But the remote is broken.
I programmed a generic remote, so I can operate the TV that way, but it won't switch between digital and analog.
Is there a way to get it to default to digital, or am I stuck buying another remote?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
I found the answer. I go into the TVs menu, and I choose to scan the channels. Right before the scan is done, it asks me whether it is digital or analog, and antenna or cable. I select digital and antenna, then exit the menu. Problem solved!
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
MrJimPhelps будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 16
За последние 30 дней: 50
За всё время: 2,211
