Repair and disassembly guides for GE Microwave ovens.
349вопросов Показать все
Replacing dead high voltage cap with similar of lower capacitance.
Hi,
The high voltage capacitor for my microwave oven has shorted. It is a 2100v, 86mfd capacitor.
I have a "spare" that is very similar: 2100v .76 mfd (so .76 instead of .86 mfd. Can I use it?
Thanks
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Without knowing more, I'd say not to use it. That particular rating may be required for the proper operation of the magnetron (the thing that generates the microwaves). GE should be able to get you the right part.
Best of luck.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
I had been hoping for an informed reply. It turns out, as I learned since I posted the question, that the high voltage capacitor is part o fhe voltage doubling circuit between the high voltage transformer and the magnetron. If the capacitance is a bit low, it reduces the final voltage - it does not quite "double" - to the magnetron, which results in a small reduction in the power the magnetron delivers, but with zero risk to the circuitry.
из
Добавьте свой ответ
H Stahl будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 139
