Airport not turning on, how to access data from the hard drive?
I believe a power surge took out the Airport Time Capsule power supply and the device is not turning on.
How do I go about accessing the data from the hard drive?
Это хороший вопрос?
Это хороший вопрос?
To be able to access the data on the Time Capsule's internal hard drive will require that you remove the drive from the base station. Then place the drive in a drive caddy or enclosure. Finally, connect the drive to the USB port on a Mac or PC. For there, you should be able to access the drive.
Был ли этот ответ полезен?
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 198
