Why do some of the buttons on my oven touch pad not work?
I have a Frigidaire brand gas oven with an electric range that has a touch pad used to control the oven (temperature, broiler, etc.). I got an f11 error with a constant beeping sound, so I tried unplugging and replugging it into the wall, which didn’t work. I then cleaned the contact points between the display layer with alcohol and now the beeping sound is gone and some of the buttons work, and others don’t (buttons #1-6, and a few others work, buttons such as “bake”, “broil”, “start”, “cancel”, and “set clock” do not). Why is this and how do I fix it?
Это хороший вопрос?
4 Комментариев
I have exact the same issues. None of my bottoms work now. Beep did go away. Digital timer still display. Did you find a solution?
из Roger Liu
The panel and buttons don't light up do so I can't program my oven
из Jeffrey Cote
I also have an electric stove and oven with a digital pad that controls the oven. Worked fine yesterday. Went to use it today and none of the buttons on my control pad work. Stove does but not the oven.
из Damon Morris
I had this happen also. All the touchpad buttons went blank. No clock display or anything. Overnight it seemed fix itself! I don't understand this. Everything came back as normal. I didn't do anything at all.
I
из Mike
