How to repair an old Mayan hammock
I am trying to repair an old Mayan/Mexican hammock that had several strings snap after many years of use. It is a thin-string, fine-weave variety, made of cotton.
The snapped strings are in the lowest area where most of the weight is when lying in the hammock and I cannot figure out how to properly weave them back in. Is there a way to do this or possibly remove an entire "strip" from the hammock getting rid of the problem and everything around it?
Other "fixes" are welcome as well. Anything that would keep me from having to just throw it out.
Это хороший вопрос?
Оценка 6
Добавить комментарий
2 Ответов
Выбранное решение
Weave in a new string to replace the section that has snapped and then use a sheet bend to tie in the new string to broken one.
I chose a sheet bend knot because it is made to combine two different ropes and would hold well even if there are severe differences in string thickness.
Был ли этот ответ полезен?
Оценка 6
use fishing line to weave in / reinforce the broken strings
plenty strong, translucent .....
Оценка 3
Добавьте свой ответ
Brian Anderson будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 14
За последние 30 дней: 31
За всё время: 9,327
