Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
412вопросов Показать все
3DS Xl turns off when opened fully
Hello my dear iFixit friends.
I got a 3DS XL that when opened all the way turns off. I Tried to secure the top screen with electric tape to that the ribbon won't wiggle but it didn't Work. I would order a replacement top screen but I am afraid it maybe the connector is what's faulty.
So If I put that rubber ring there It works fine. No reason still I will continue to investigate.
Это хороший вопрос?
Оценка 1
3 Комментариев:
Yeah the same happened with me too. Ive been trying to find a way to fix this
из
Good luck did you try to replace the top screen? Aliexpress has seller who sell dirt cheap ds/3ds/n3ds screens!
из
@robsferic Yeah i'm going to try and do that and hopefully it will work again. Thanks for the advice!
из
Добавить комментарий
1 ответ
My friend is sending me 2 faulty 3ds’s he has, and if i can repair them, i get to keep them. The 3ds xl one has the issue you’re describing and from what i can tell, it’s a issue with the ribbon cable https://youtu.be/8UifkXEkV-0 see this video for details.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Thank you for the response! I gave the 3ds back and told them to get a 2ds, people only want quick and cheap solutions. Still I hope you fix it!
из
Добавьте свой ответ
Róbert Fekete будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 11
За последние 30 дней: 60
За всё время: 6,164
