Grass is normal, why do the blades slow down after I begin cutting?
Grass is normal height as always, when I begin to cut the blades slow down at times almost stopping while engaged. Tention is on belt. I even turned belt over. I have not changed the belt since having the mower, 6/2016.
Это хороший вопрос?
3 Комментариев
I replaced the filter and it continues to do the same.
из Cedric Watson
You might have contaminated gas in the mower. Drain out the old gas. Change the fuel filter. Get new gas, non-ethanol if possible. Mix in some Seafoam gas treatment with the new gas. Fill your tank with the gas/Seafoam mixture. Now crank the engine. The Seafoam will clean out your fuel system. If the problem was with the fuel system, then the Seafoam will solve your problem.
https://seafoamsales.com/small-engines/
из MrJimPhelps
What would gas have to do with it? My blades slow down too but not the engine speed my belt also has tension on it.
из Kevin
