7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
220вопросов Показать все
Slight Screen Repair Issue
Hey there I was attempting to take the digitizer off my badly shattered iPad Mini 1 Space Grey and it was cracked so badly there are still chunks on it in really tiny pieces any ways I can save it so I can successfully put the new digitizer and LCD in thank
Ps if you can’t visualize I can add a photo
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
You'll have to scrape them off, with some form of flat tool. Try putting some IPA or Acetone on them first to soften up the adhesive. Once that is done, you'll want to remove all of the adhesive from the frame (use IPA/Acetone again) before putting the replacement digitizer back on.
Some replacement digitizers have poor quality adhesive pre-installed so you may want to consider applying a high quality adhesive such as this one.
Tesa 61395 Tape Изображение
Продукт
Tesa 61395 Tape
$5.99
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Thanks I’ll try that ipa has solved so many issues before
из
Добавьте свой ответ
Ben Cybulski будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 43
