Dropped camera now it won't turn on.
I have just purchased a used Sony rx100 Iv that will not turn on. The previous owner says the device was dropped and after that wouldn't turn on. Any idea what could be weong?
Это хороший вопрос?
Это хороший вопрос?
cellphonebuyer1 this could be related to a battery issue, check the battery contacts and do not forget the battery door. It could also be an issue with the main board and dislodged power flex. Sony’s camera all pretty much come apart the same way. Take a look at these guides and see if you can disassemble your camera. take plenty of pictures when you do so and post them with your question. that way we can see what you see. Use this guide Adding images to an existing question for that.
Был ли этот ответ полезен?
Hello, which flex cable is the power flex?
Step 16 and 17 in the above named guide show the ribbon cables. You will have to disassemble your camera and take a look at all of them.
Did you turn it on and try it out before buying it? If not, then I would say that it was broken when it was dropped. Even if you did turn it on before buying it, it is still possible that it was broken when it was dropped.
old turkey03 did you fix your camera. I am scared to try
За последние 24 час(ов): 2
За последние 7 дней: 15
За последние 30 дней: 52
За всё время: 4,974
3 Комментариев
So I fixed the camera. I am not to sure what actually fixed it but I just fully disassembled the camera and reassembled it and now it is working.
из cellphonebuyer1
cellphonebuyer1 excellent! Sometimes just reseating things can fix slight misalignments
из oldturkey03
@cellphonebuyer1
cellphonebuyer1 how much did you disassemble the camera? I have the same problem...
из jquad
