The LG G Pad Tablet 7.0 was released in 2014, it is an Android based produced by LG. This device is the first produced tablet with a 7 inch screen and a 1.2 GHz Quad-core processor. Model number LG-V400.
14вопросов Показать все
My Tablet Won't Charge!
I have tried over 8 charging cords and it won't charge, If this helps, all of the cords feel very loose when plugged into my tablet and they pull out easily. Also If it does tell me it is charging, a couple minutes later it tells me it has stopped charging because it doesn't recognise the cord. They are all the right cords because they fit the port on it. Any answers are much appreciated!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
@bunnybunny
“cords feel very loose when plugged in “ pretty good indication that your port is the actual issue. Take a look at this guide LG G Pad 7.0 Motherboard Replacement The charging port is mounted on it’s own flex cable. Replacing that with something like this should fix that.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Jacob будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 117
