The Chevrolet Tahoe (and its rebadged version GMC Yukon) is a full-size SUV from General Motors. Chevrolet and GMC sold two different-sized SUVs under their Blazer/Jimmy model names through the early 1990s.
109вопросов Показать все
Why doesn’t the air in the backseat come on?
The air in the backseat of my 2002 Tahoe doesn’t not give any air. The front works great but the vents above the backseat and rear don’t give any air. The lower vent in the rear works too just none of the vents on the roof of the car.
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
I would start with the fuses. There is a 30 amp fuse in the fuse block under the hood. Another fuse is in the interior panel. I believe it is titled IGN 3. If those are not the issue you may have to access the blower motor in the rear of the SUV.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Evelyn будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 8
За последние 30 дней: 10
За всё время: 488
