2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
774вопросов Показать все
Why is my display not working?
About six months ago, I splilled water on my MacBook. I took out the logic board and cleaned it. Everything worked properly. I decided to clean the logic board again when I installed a new trackpad cable a few days ago. Upon reinstalling, the display doesn't work. I am able to use the computer fine with an external monitor. I can't figure out if it's a problem with the display socket on the logic board or if I should purchase a new replacement display.
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Выбранное решение
It's impossible to answer your question without testing the logic board, or trying installing a known good screen. Given the history of your Mac I'd be more inclined to think about a logic board failure. Lvds connector and lcd enable circuit would be the first to check in my opinion.
Был ли этот ответ полезен?
Оценка 1
Take a flashlight and shine it through the Apple Logo. Are you able to see your desktop icon’s? If you do then your issue is within the backlight circuit. It could be as simple as a burnt fuse link or needing a new driver chip.
Оценка 0
Добавьте свой ответ
Sam Quinn будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 5
За всё время: 107
