Released June 2017, the iPad Pro 10.5" replaces the 2016 iPad Pro 9.7".
145вопросов Показать все
Home Button not working after Install, Need HELP PLEASE!
Hey recently screen broke found replacement somewhere else since part is not instock. During screen replacement home button was severed so I had to replace as well. Although I know touch ID functions wont work but home button doesnt seem to work at all. I'm 99.9% install was correct any ideas on why it wont work? Also ipad was reseted before i installed so I was able to turn on assistive touch. Will I be able to turn on assitive touch again if I restore to original apple ID which didn't have it on already or will it just be locked out after?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Hello
If a home button is damaged I mean (print fingers )you can not replace it with new one but the new home button without Touch ID will work as just home button
Good luck
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Lucky будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 7
За всё время: 92
