Yellow Triangle on Android Motorola G4
All I get is a yellow triangle with exclamation mark. Have tried to go to reset Factory Settings, but still only get yellow triangle. Local repair facility suggested that I reload OS. Is this possible?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Just plug In a known good charger. Wait and it will come back to life. DO NOT FACTORY RESET. NO REASON TOO
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
You were so right, as my charger came loose from the wall and promptly died after I left home. Started charging when I got back and it rebooted and I'm good to go. At first, I thought your answer was way too simple, to the point I thought it was a dumb answer. I was wrong and you were right. Thanks!
из
Always glad to help
из
the yellow triangle is just a general failure on the device. it can be anything really.
follow these steps to enter recovery mode. https://www.youtube.com/watch?v=MvDN0UQS...
from there, you can ractory data OS reload. PLEASE BE ADVISED: this will wipe all of your data on the device. you will lose photos, contact, videos, and any other personal files.
if this doesnt work, i usually find that this is commonly a battery. however, it can also be a board level issue.
Оценка 0
2 Комментариев:
Scott, sorry but once I select the Recovery Mode, I still get the yellow triangle. I cannot even get a charge on the battery. Someone suggested that this indicates corrupted OS. Can the OS be re-installed on these phones.
из
should be able to force load the OS through ADB
this is a generic walkthrough on setting it up, but you may need to locate your ROM on the internet.
https://www.howtogeek.com/125769/how-to-...
из
Добавьте свой ответ
Don Brown будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 29
За всё время: 19,628
