Kia introduced the second generation (JB) in the early 2005 model year in Europe and for model year 2006 in North America, based on a redesigned platform shared with the Hyundai Accent.
11вопросов Показать все
How to check if my 2007 Kia Rio base model cooling fan works?
How do I check if my 2007 Kia Rio base model cooling fan works? We are replacing the radiator because of a "bug puncture", but the fan doesn't seem to be running either. Is it suppose to run all the time or just when the car heats up?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
Electric engine-cooling fan motors only run when the thermostat opens or coolant temperature reaches a set temperature.
So no, it doesn't run all the time.
edit: to check the operation of the cooling fan, with the radiator fixed, let the car run for 5-10 minutes, this should be sufficient for the engine to heat up and meet the criteria for the fan to start. Just keep an eye on the intrument-cluster for coolant temperature so that it doesn't overheat.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
reneesown2 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 15
За всё время: 994
