LG Power Tracfone, ran on Android's 5.0 Lollipop platform with a 4.5" FWVGA Display, Model (L22C).
How to turn on USB Debugging (Power button broken, and phone off)
Hello. First of all, thank you for reading this.
My issue is that I want to turn on USB debugging so I can use ADB to turn on my phone, since my phone died and my phone's power button is broken. But, I cant use ADB since I didn't enable USB Debugging in the first place. Is there a way to turn on USB Debugging without using a power button and turning on my phone? This happened when I accidentally put my phone in a deep puddle. After that, my back panel got wet and then my power button wouldn't respond anymore.
Thanks for reading
Это хороший вопрос?
Счет 1
4 Комментариев
I hope there is a solution to fix this problem. I suffer from the same problem.
из
It trun on went back of
=== Update (03/02/2019) ===
Help me fix it
Don't know what to do
из
Yes it and don't working now
из
What can I do
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
There is a sort of last ditch effort to try and turn on the phone without the use of the power button but there is risk of damage to the phone. It requires disassembling the phone to get the power button soldering points and bypassing the power button with some wire. This will turn the phone on but at your own risk. If you decide to perform this option, you do so at your own risk. I am not liable for any damage that you cause to your phone.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
I applied it yesterday and I solved the problem. There is no other choice to fix it but some phones can be turned on by shocking. If you want to use shocking, the battery must be removable. plug in the phone charger. after turn on the screen, remove charger and battery. then plug in the battery.
из
Hi, i’ve read your problems. But i’m sorry to tell you that there is no way. I hope you understand ):
Счет 0
Добавьте свой ответ
Arai Natsuki буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 12
За последние 30 дней: 28
За всё время: 2,339
