Can a broken mounting peg on an analog stick be repaired?
The right analog stick was non-functioning. Upon disassembly, I found the mounting peg for the stick to be broken in two. The base of the peg still appears to function, but can the two pieces be screwed and glued? I think a replacement would be a better option, but how? This controller was bought "modded" for rapid-fire for $60, so the replacement cost is higher than a regular wireless controller. Any ideas?
Это хороший вопрос?
Счет 1
1 Комментарий
Depending on the thickness of the plastic you may be able to drill holes in either part and put a metal rod/pin etc use modelmakers glue to strengthen bond? I need to see it for myself to answer properly but this has worked in the past... You need a very fine drill bit..
из
Добавить комментарий
1 ответ
Выбранное решение
With out seeing pictures I can't tell you about gluing it. But I believe this is the replacement part you are looking for here.
Был ли этот ответ полезен?
Счет 1
1 Комментарий:
Sounds like a cheap part and less hassle than my idea!
из
Добавьте свой ответ
marty буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 1,399
