Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
Why Is My Phone Stuck on Boot Loop After Liquid Damage?
Hi, first of all I would like to say I'm not looking for simple answers, i.e - hard reset, disconnect / reconnect battery. I would like to know if anyone out there, all be a technical genius could answer my question and give me some pointers. Now I'm no professional at phone repairs but I've done a fair few to understand the basics. I've never done any IC soldering / repair nor can I due to lack of equipment.
Basically, my question is this: Why is my iPhone 6 stuck on a boot loop when plugged into mains power but will not turn on independently via usb to pc or by it's own battery (new battery). The phone I believe has suffered water damage and after inspecting the pcb I noticed a scorch mark on the lower part of the board's shield. I have no idea what IC's to look at or what areas to look at first.
I've noticed that some of those IC's have suffered some damage and I believe maybe some of the board's ceramic caps are missing / damaged. I only have a soldering iron and a conventional multimeter, so any starting point would be good.
Any information regarding that would be great. Thanks.
https://ibb.co/heom3d
https://ibb.co/dPM63d
https://ibb.co/gmPFwy
https://ibb.co/fXWvwy
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
ok brandon your phone can bootloop with shorted components but finding the actual component can be difficult if you don't have a dc power supply. i suggest you take a look at the capacitor to the left of the wifi chip even if you knock it of the phone will still work
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
Thanks. Do you by any chance know where I can find a diagram / schematic of the iPhone 6 logic board? I don't know where what IC's sit where.
из
possibly a zxw file type from gsmforum
из
Добавьте свой ответ
Brandon Frost будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 80
