Проводной контроллер Afterglow Prismatic, выпущенный 25 октября 2015 года, представляет собой контроллер для Xbox One, созданный компанией PDP, производящей аксессуары для видеоигр.
The left thumbstick clicker button will not click...
Hi guys. My son's Xbox One Afterglow controller's left thumbstick button will not click when the thumbstick is pushed forward. This is super annoying when trying to play Battlefield 1, because that happens to be the run button.
Couple of things :
I dunno how the damage was done, my son did it and he's pleading the fifth...
The button does click on almost all other positions and there seems to be no catchiness in the movement of the thumbstick.
I have noticed the left thumbstick will pull up almost half a centimeter, whereas the right has zero upward play.
Any suggestions or answers you already know are very much appreciated. There had been an aborted attempt to open up the controller but I was weary on how much force should be required to separate the two halves of the case. But I plan on a reattempt...
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Its sounds to me like the joystick assembly for that side has broken. These parts are mad from plastic and are not the most sturdy of parts. A replacement part can be installed if you can solder. The part shold run about $6-$8.
Dan
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
how do i do this??? like how do i get it installed???
из
Добавьте свой ответ
Jeremiah буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 36
За все время: 6,174
